I have the stock plugins for the fog lamps and i know that there is a fuse for them, what i realy need to know is how do they turn on? Do they turn on when you turn on your headlights, or will i need to put in a switch for them and if so where is this switch in the car and what does it look like. I dont have the lights yet. so i cant just go test stuff so if anyone can help me please let me know.
Thanks, Culligan |
Man w/ CTSV & a Car Seat
From wut i remember, theres a switch on the headlight switch. Its a ring toggle switch. You can only turn it on or off when the headlights are on. You cant turn it on when the headlights are off.
![]() Join Date: Dec 2002
Use the OE switch, or pull the column cover and there's a 2pin plug, black and green/orange, tie them together.
Fogs are powered only with the lowbeams, you can rewire the relay to change that. I've detailed it before on FA, do a search.
