Old 02-25-2002, 08:45 AM   #1
NiteKids
NiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymore
Send a message via AIM to NiteKids
97 240SX SE Manual
Just this morning I noticed when I let my E-brake down to leave for school this morning the light on the gauges that my e-brake is up does not turn off.  I tried to put the brake back on then off and hopefully that would make it go off but it didn't!  Anyone know what could be the problem?
NiteKids is offline   Reply With Quote
Old 02-25-2002, 08:51 AM   #2
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
make sure your brake fluid is full.
sykikchimp is offline   Reply With Quote
Old 02-25-2002, 09:36 AM   #3
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
#Moderation Mode
<a href="#/forums/cgi-bin/topic.cgi?forum=2&topic=2158" target="_self">Moved here</a>
ca18guy is offline   Reply With Quote
Old 02-25-2002, 09:39 AM   #4
NiteKids
Uh where do I refill my brake fluid at?
Old 02-25-2002, 10:05 AM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
There is a low and high level on the side. &nbsp;If that is fine, then the sensor under your center console may be getting pressed somehow.
Old 02-25-2002, 03:32 PM   #6
JDM S13
JDM S13 is an unknown quantity at this point
ya, check your brake fluid. &nbsp;my light stayed on and I found out my master cylinder was leaking <img src="#/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('>
JDM S13 is offline   Reply With Quote
Old 02-25-2002, 04:00 PM   #7
blaqsilvia
blaqsilvia's Avatar
blaqsilvia is an unknown quantity at this point
check ur brake fluid dude! :wink:
blaqsilvia is offline   Reply With Quote
Old 02-25-2002, 04:42 PM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
yeah.. &nbsp;check your fluid...
Old 02-25-2002, 08:50 PM   #9
Arcane
Arcane is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from JDM S13 on 3:32 pm on Feb. 25, 2002
ya, check your brake fluid. my light stayed on and I found out my master cylinder was leaking <img src="#/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('>
</td></tr></table><span id='postcolor'>
same problem here....you may want to check your fluid...don't know if anyone has mentioned it before....if it's low....check to see if your maaster brake cylinder is leaking....
Arcane is offline   Reply With Quote
Old 02-25-2002, 09:00 PM   #10
DSC
New Title
DSC is an unknown quantity at this point
Yeah, check your brake fluid man. &nbsp;hehe, i think he'd probably do it on one recomendation <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
I had this same problem a while back tho, brake fluid was low, put some castrol dot 3/4 in, good as new.
DSC is offline   Reply With Quote
Old 02-26-2002, 03:55 PM   #11
Sick240
Sick240 is an unknown quantity at this point
the brake fluid was probably your problem, but if it is low, and nothing is leaking, then your pads are getting worn, and you should probably replace them before you start braking with rivets and put nice huge grroves in your rotors, lates
Sick240 is offline   Reply With Quote
