1982 280ZX Turbo
I have 82 280ZX turbo and i am having a problem with it i just got it my problem is when i start taking off from a light and i try to give it full throttle its like i lose power it just falls to its face all i can do is take off really slow and eas up to 3100 RPM's then it stars picking up go it only runs good when its over 3100 RPS's Give me some ideas to test and check out.
![]() Join Date: Jan 2007
is your distributor vacuum advance? i forget....i never keep the L28 motor in there very long. as soon as it gives me a reason to pull it out...i do lol.
it could be your tip in throttle... do you have any kind of adjustability with the tune? if it is vacuum advance, that initial drop in manifold pressure may cause it to knock or not have enough timing. it could be as easy as a bad tps, or the ignition timing being off. i'd probably start by checking those 2 things. it could be stuck/rusted up weights in the distributor, you could pop the cap off and clean it. make sure everything can move freely. it could also be the maf adjustment. it's a 30 year old car, those springs get weak. i've had to tighten up the last 2 z's i worked on. obviously before you move it mark where you started, then try two or 3 teeth in one direction, see if that helps, if not , go back to your mark and try 2 or 3 teeth in the other direction, but DO NOT let the spring unwind because you will NEVER get it back adjusted properly i've been told. that warning scared me straight so i've never had that problem cause i'm extra careful, but it's not uncommon to pop the maf cover off and have to adjust the cog on the maf for those cars. i'd check the other things i suggested before you mess with the maf tho. other things you probably wanna check are boost leaks, hopefully you've already done that tho. anyways, i saw nobody offering any help, so hope that helps. Dave |
![]() Join Date: May 2007
Unhook your battery. Unplug the computer (by your left foot in the drivers side panel.). Plug computer back in, then battery. Start. Let it ide for about 10 mins or so.
Drive it like you stole it. My Z has the same problem now and again, I need to go back through the electrical this next winter.
1982 280zx Turbo |
#4 | |
unplug the TPS when setting 280zxt ignition timing
![]() Join Date: Dec 2008
does this apply to ka24de as well?
