![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
Godspeed Project RS-Series Wastegates!!! SALE!
38mm RS-Series Wastegate
- Includes a 5psi & 10 psi wastegate spring (combine both springs for 15 psi) - Dual port = accurate boost - Ultra durable diaphram - Includes all hardware (bolts, gasket etc) - High quality appearance - Quick and simple one step process for removal or installation of a different wastegate spring - 1 year warranty with professional installation This wastegate is 4.00" inches tall. 5 psi spring : outer diameter 29mm / length : 36mm 10 psi spring : outer diameter 44mm / length : 68mm You can use the 5 PSI or 10 PSI spring alone or combine them together for a total of 15 PSI. $75 Shipped to the Inner 48 States (CA Customers pay sales tax) 44mm RS-Series Wastegate - Includes 5 psi & 10 psi wastegate spring ( combine both springs for 15 psi ) - Dual port. accurate boost - Ultra durable diagram (diaphram) - Includes with all the hardware (bolts, gasket etc) - Accurate boost pressure - High quality appearance - Simple one step process for removing or installing different wastegate springs - 1 year warranty ( if installed by professional) This wastegate is 4.10" inches tall. 5 psi spring : outer diameter 29mm / length : 36mm 10 psi spring : outer diameter 44mm / length : 68mm You can use the 5 PSI and 10 PSI spring alone or combine them together for a total of 15 PSI. $95 Shipped to the Inner 48 States (CA Customers pay sales tax) 50mm RS-Series Wastegate - Includes 2 x 7psi spring, 1 x 14 psi spring (can be combined up to 28 psi) - Dual port. accurate boost - Ultra durable diagram (diaphram) - Comes with all the hardware (bolts, gasket etc) - Accurate boost pressure - High quality appearance - Simple one step process for removing or installing different wastegate springs - 1 year warranty ( if installed by professional) This wastegate is 5" inches tall. 7 psi spring : outer diameter : 36.5mm / length : 93mm 7 psi spring : outer diameter : 59mm / length : 85 mm 14 psi spring : outer diameter : 49mm / length : 113mm You can use the 7 and 14 psi spring alone or combine them up together for 21psi. By using all three springs together, will get you up to 28 psi max. $120 Shipped to the Inner 48 States (CA Customers pay sales tax) 60mm RS-Series Wastegate - Includes 5 psi, 12 psi, and 14 psi springs (combination of 31 psi) - Dual port = accurate boost - Ultra durable diagram (diaphram) - Includes all hardware (bolts, gasket etc) - High quality appearance - Simple one step process for removal or installation of different wastegate springs - 1 year warranty with professional installation This wastegate is 5.5" inches tall. 5 psi spring : outer diameter : 36.5mm / length : 75mm12 psi spring : outer diameter : 59mm / length : 121mm 14 psi spring : outer diameter : 49mm / length : 108 mm You can use the 5 PSI / 12 PSI / 14 PSI spring alone or combine them together. By using the 5 PSI & 14 PSI spring, you will get 19 PSI . By using all three springs together, you will result in 31 PSI. $140 Shipped to the Inner 48 States (CA Customers pay sales tax) For any orders please contact Chris @ Godspeed Project. (EMAIL) [email protected] (Phone) Chris (626) 442 - 3988 Monday to Friday 9AM to 6PM
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
Yes Mace! Let me know when you are ready!
Pm sent!!!!!!
bump for the wastegates! in stock and ready to go!
Columbus day bump!!!
all wastegates in stock!!!
bump for the wastegates!!!
wastegates in stock and ready to go out
wastegate bump!
Almost Christmas Monday Bump!
