![]() Join Date: Jul 2007
Trader Rating: (106)
S13 SOHC Injen intake and ASP crank pulley
SOHC ASP crank pulley
This is an ASP crank pulley for a SOHC KA. The pulley is in great shape, only small marks on the backside from removing it. It does underdrive the water pump and alternator. It is also sleeved for the crankshaft seal so it won't wear and leak. Altogether this is a REALLY nice pulley, I wish it worked on a dualcam... SOLD! SOHC Injen intake This is a COMPLETE Injen intake system for a SOHC KA. EVERYTHING you need is included, just bolt it in and go. Also included is a custom bracket if you do not have the stock fan shroud. You would need to get a rubber mounting bushing or put together a spacer arrangement to mount the bracket though as I re-used the mount bushing on my dualcam intake. $80 Last edited by racepar1; 07-23-2015 at 08:52 PM.. |
