Ruckus-Racing 1jz/2jz mounts 240sx
Ruckus-Racing s13/s14 1jz/2jz swap mounts ![]() these are our very own 1jzgte/2jzgte swap mounts for the s13 and s14240sx chassis. Our mount kit sets the engine as far back in the engine bay asa we could fit it without losing use of the heat core. Also we set the engine as low as possible for good hood clearance. We have made this kit to allow you to use your original 240sx rubber mounts. The transmission crossmember is made to use the R154 transmission.This kit includes two engine mounts, one transmission crossmember, and sway bar spacers(only needed in certain cases). Also drive shafts and wiring harness services are available upon request. The kit is made from high grade mild steel. 100% tig welded. We offer a limited lifetime warranty. dealer inquiries welcome. price$350.00 +shipping additioal info please contact Ruckus-Racing.937-520-0284 ![]() ![]() |
Excellent!! Easy & cheap 1JZ mounting for S chassis! Please post basic price guidelines for wiring and driveshafts (with and without core exchange, if possible) so window shoppers can get an idea of what a 1JZ/2JZ swap will cost.
ok here you go.
wiring s13/s14 currently we do not offer A/C but we are working on it. but the price without A/C is $300.00 with a rough 2 week turn around time. with A/C when we get it all tested. it will be $350.00. this will get the car running. It does not include the adapters for the speedo or tach if you want them included its like around $140.00 for the two. check ebay to make sure. driveshafts are $450.00 (best we can do). it is a one piece steel shaft with heavy duty yolks. holds upwards of 800hp. Thats what our supplier told me. any other questions just let me know. also we are working on a shifter extension should have it up for sale in about a week |
![]() Join Date: May 2005
just when i bail out of my S14 2jz project and buy a TT supra.. lol. If your parts are good quality items, then you are going to be a welding fool lol. your prices are awesome man
Hmm.. interesting. Do you have any pictures of a 2JZ installed on a S14 using your kit to show how the 2jz sits with this setup? Very interested waiting on feedback and pictures.
have you solved the issues other companies are having with the speedometer? After installing my 2jz we cannot get the speedo to work? Does your 2jz swap have the working speedo?
![]() Join Date: Apr 2003
Wiring will not be sold without 100% test. That is why a/c isnt a current option. I can easily make it work but I want it to work just like the factory does ie you hit the button idle jumps up, you go wot, a/c shuts off. I like to make 100% sure of something before I mention it. On paper everything is easy. Just like anyone with a romulator and live edit can tune. The exact devices to use will be listed with your harness or you can buy them from rucas if you don't mind paying a little extra for convience. THe harness will also come 100% in tact. there will only be clearly labled wires for installing the speedo and tach boxes. All wires will be loomed and plug into your car just like factory as long as the 240 harnesses you send in fit your car ie dont send an 89 auto harness if you own a 93 5 speed. Just like any company you will be charged for missing plugs, but fairly. You are missing a tps plug, you will not be charged $100. harness being hacked in half is another story, but I think that goes without saying.
This is Autotroniks posting under slw240sx's name.
http://www.forcedfabllc.com/ |
#22 |
Ive also got a ls1 sitting here if anyone has a tranny
We should be firing the car on the beta harness in the pm of tomorrow.Joel
#23 | |
Joel
#26 |
To Ruckus, Seeing that I have a built 2JZGE (NA-T) complete with harness and built auto trans could you sell me just the motor mounts, or could you make a tranny mount for the auto tranny?
#27 | |
here they are one more time: $60 - Housing, Shifter (33521-24040) $16 - Control Shift Lever (33570-24010) http://forum.clubna-t.com/showthread...fter+extension Last edited by nasx; 02-28-2008 at 01:25 PM.. |
#29 | |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
