Old 03-03-2011, 12:35 AM   #1
na12uto
na12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-known
Kazama tie rod ends bad??
I went to go get an alignment and i was told taht my tie rods are bad. I have kazama tie rods inner and outer for about a year now. The shop said they couldnt do the alignment because the tie rods are bad... how often do tie rod ends go out is my question.... i call bs on the shop but when he jacked up the car he was able to wobble the wheel a little so he might have a point.
I do believe my ball joints on my control arms are bad and i will be replacing those but would that be the case??
Kazama tie rods just look well put together so I dont want to believe they are bad and if thats the case what would the cheapest best solution be since kazama tie rod ends arent cheap fml
A day late, a buck short, nothing zip ties cant fix
na12uto is offline   Reply With Quote
Old 03-03-2011, 07:44 AM   #2
sr23det
sr23det is an unknown quantity at this point
you might want to look into it more, tie rods, wheels bearings , ball joints , etc.....
sr23det is offline   Reply With Quote
Old 03-03-2011, 07:48 AM   #3
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
I have seen a set wear out and they do have play on the spherical joint.
This was after 6 years of driving and then sitting for 2 years.
I think your LCA bushing is bad.
lok is offline   Reply With Quote
Old 03-03-2011, 08:22 AM   #4
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
Make sure everything is tightened down before you go buying anything. I had some wheel play, the top nut on my tie rods were loose. Kinda scary.
Pandapants is offline   Reply With Quote
Old 03-03-2011, 10:16 AM   #5
Souljahzs13
Souljahzs13's Avatar
Trader Rating: (66)
Souljahzs13 is an unknown quantity at this point
Feedback Score: 66 reviews
Both my buddy and I had bad outter kazama tie rod ends after about a year, we went through baker precision to replace the spherical bearings with auroa's. Another buddy of mine that is also a member here on zilvia had a bad case of worn oem ball joints on the flca and inner tie rods. Can be easily be checked by jacking up the car and shaking it with lateral movements at each area to fine the free play
Souljahzs13 is offline   Reply With Quote
Old 03-03-2011, 12:59 PM   #6
na12uto
I see so even the best stuff does give out :/ and i am going to buy lower control arms that already have ball joints in them on ebay since it seems to be the easiest on labor.
And I dont know who or what baker precision is but ill look into it?? I might as well change the outer tie rods if they are already bad. If im not mistaken the tein outer tie rods are interchangeable with kazama's right?? Is there any other brands cause Teins dont look that reliable
Old 03-03-2011, 01:07 PM   #7
Touge Noob S13
Touge Noob S13's Avatar
Touge Noob S13 is making a name for him/her selfTouge Noob S13 is making a name for him/her self
Teins use the oem style ball joint with dust boot. I dont see how they dont look reliable. Spherical ends are more susceptible to wear. I have SPL V4 outers on my car for 2 years and the ends are still good.
The things people will do for a green card.
Touge Noob S13 is offline   Reply With Quote
Old 03-03-2011, 01:18 PM   #8
na12uto
ok see thats good to know and i was actually thinking of picking up some of the circuit sport outers, but if they dont fit the kazama's im going to go tein outers.
Old 03-03-2011, 01:55 PM   #9
Souljahzs13
Trader Rating: (66)
Complete Product Index - Baker Precision
Old 03-10-2011, 04:04 PM   #10
na12uto
so i did shake the wheel and found very very little play left to right i mean a little, I did just get new flca's with ball joints (not installed yet) and i checked the ball joints on the rods, (took them off and noticed that the ball does have little to none free play (the rubber inside is ripping very little)
