![]() Join Date: Oct 2008
Guys, I recently bought a rear diff cover for an LSD, I then realized it came with nothing. I'm sure I can find some bolts from some hardware store but I was wondering what do I do about the breather tube? Is there anyway I can make my own? I've searched but was unable to find anything regarding this. Thanks.
This is what I picked up from FRSports |
#2 | |
As far as the breather tube goes, can you remove the tube from your OEM diff and install it in the new cover? If not, the breather is just an atmospheric vent, I'm fairly sure that you can run with just a hole - though I'd suggest putting mesh or something over it to keep dirt/rocks/etc out. |
I'd figure out what cover that's from and just try to buy a used one with all the studs/breather tube already on the thing. I've tried messing with those studs before and they are a bitch to get them to stay in the diff cover if ever removed. I tried removing the breather tube from my s14 cover a while back and ended up destroying it.
Also that diff cover should have a splash shield type thing for the ring gear on the inside... might not be good if that's missing as well. |
#4 | |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
Using bolts would more likely cause the inside of the holes to strip on the cover if you don't have the diff aligned perfectly. Having the studs in the cover help to guide the diff into place, not to mention hold the diff up (when not bolted) so it doesnt fall on you.
![]() Join Date: Jun 2010
Trader Rating: (32)
![]() Feedback Score: 32 reviews
EVERYTHING you need (Studs and Breather) can be obtained brand new from NISSAN for under $20.. I know this because I bought new studs and breather for my JDM VLSD Diff Cover (Item pictured from FRSport)..
![]() You cannot remove the old breather without mangling it up a little around the lip.. |
| breather, cover, lsd, studs, tube |
