![]() Join Date: Mar 2005
Megan Racing Street Coilovers for S13 and Z33 instock!
Welcome board members,
Here to bring you some affordable coilover systems from Megan Racing. They all come with 1 year Factory Warranty from date of purchase. Street Coilover Features: - 32 Levels of Damper Force Adjustment - Pillow Ball Upper Mounts with Front Camber Plates - Rubber Dust Boots - Adjustable Ride Height - Aggressive Spring Rates - Single-Cylinder Design - Aluminum Brackets - All coil-over damper kits come with 1 year manufacturer-defect warranty. - All Hardware is Included S13 SPRING RATES: F: 62mm ID; 180mm length; 8 kg/mm R: 62mm ID; 220mm length; 6 kg/mm S13 DAMPER SPECS: F: 120mm stroke; 260mm length; M2 valving code R: 115mm stroke; 220mm length; A1 valving code Picture of damper adjustments Z33 SPRING RATES: F: 62mm ID; 200mm length; 10 kg/mm R: 62mm ID; 200mm length; 8 kg/mm Z33 DAMPER SPECS: F: 135mm stroke; 270mm length; A2 valving code R: 135mm stroke; 240mm length; A1 valving code Picture of damper adjustments Any questions or Special forum pricing please contact me via PM, EMAIL, AIM, or CALL IN. (LOOK AT THE SIG) Thanks, Tuan @ A Spec
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan Advertiser's Specials! Read / Give Feedback! Please Rate Us!
Replied via PM.
Thanks, Tuan @ A Spec.
