Old 04-03-2014, 12:45 AM   #1
Shopety2012
Shopety2012's Avatar
Shopety2012 is an unknown quantity at this point
rocker arms and solid lifters?
SOMEwhat new to sr's. Doing a balls out build. The whole wrap sheet. So talking head stuff, going with the tomei solid lifter kit for obvious reasons, my question is... on some random threads in the past i remember seeing people receiving their rocker arms in bags after being sent for some kind of treatment, and also some sort of modification to the rocker arms that has something to do with the solid lifters. I want to know what treatment (even though its probably cryo), and also what kind of modification relate to the solid lifters, and why?
if you have any questions about my build id love to share, answer, and talk (: since nobody else really cares lol
thanks, tyler
Shopety2012 is offline   Reply With Quote
Old 04-03-2014, 06:55 AM   #2
TheRealSy90
TheRealSy90's Avatar
Solid lifters are a waste... Do dual rocker arm guides.
Such a good signature.
Old 04-03-2014, 07:04 AM   #3
JBB
JBB is an unknown quantity at this point
get a p11 cylinder head
JBB is offline   Reply With Quote
Old 04-03-2014, 07:12 AM   #4
Def
This. Don't waste your time with a DET head.
DEFSPORT
Old 04-03-2014, 07:25 AM   #5
Shopety2012
can you explain why they are a waste? knowledge is power
Old 04-03-2014, 09:21 AM   #6
mewantkouki
Trader Rating: (36)
mewantkouki is making a name for him/her selfmewantkouki is making a name for him/her selfmewantkouki is making a name for him/her self
Feedback Score: 36 reviews
Sr20det head is a waste... lol
Google p11 / p12 cylinder head.
The biggest difference is the rockers are shaft mounted so no poppage at high rpm. They also flow 2X better than a det head. VVL rocks my socks!
mewantkouki is offline   Reply With Quote
Old 04-03-2014, 09:57 AM   #7
Shopety2012
Yes I've read about them plenty of times, but how hard are they to find? I've probably looked 3 different times trying to find one but no luck. I was just going to build the head I have, and force CFM down it's throat
Old 04-03-2014, 09:58 AM   #8
GabeS14
GabeS14's Avatar
There are big cams with springs meant to maintain the stock lifters, without danger to them,
C2 JWT cams for example..
if you haven't already purchased all that stuff, hmu, I have a kit I have been holding onto for 4 years, but don't need, willing to let go real cheap..
I was going solid lifters too, but then learned about these back in the day.
Old 04-03-2014, 10:08 AM   #9
EatRice
EatRice's Avatar
EatRice is an unknown quantity at this point
I have a full solid head for sale with full port job supertech TI retainers
dual guide setup ect ect
- HMU
EatRice is offline   Reply With Quote
Old 04-03-2014, 10:38 AM   #10
Def
Just buy a P11 SR20VE and toss the block away (has very little value, maybe $100 max to a FWD SR guy). You can get the engines for <$800 with ease.
DEFSPORT
Old 04-03-2014, 10:42 AM   #11
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
To piggy back off of Def, a complete VE swap or long block is your best bet. It'll have everything you need for the swap minus some necessary parts.
My SR20VET
Old 04-03-2014, 06:33 PM   #12
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
If youre going balls out and plan to spend $2k on the head then yea, minus well go VE head.
I see solid lifters and Cam combo go for pretty cheap now a days so if your budget is lower then that I still suggest keeping the DET head. I believe what you are referring to is people sending in their rocker arms to get machined so both sides can use rocker arm guides instead of a shim and rocker guide for each rocker arm. This is the better way to ensure your rocker arms dont fall out during high revs.. it also eliminates the use of rocker arm stoppers, because they actually dont solve the rocker arm problem.
PeaceOnesxWai is offline   Reply With Quote
Old 04-03-2014, 06:51 PM   #13
Shopety2012
Good info, this thread actually is the first time I ever heard of dual guide. It makes perfect sense.
Old 04-03-2014, 08:14 PM   #14
JBB
this is for the length of my message because apparently quotes dont count
Old 04-04-2014, 07:09 AM   #15
TheRealSy90
Like he said, you have the rocker machined to accept a guide shim on the other side so you run dual guide shims. You will never pop a rocker, also a good camshaft helps like the almighty JWT S4 cams. Stoppers just break the rockers and you don't have to spend a shit ton on a vvl head that is not as easy as it sounds.
Old 04-04-2014, 08:29 AM   #16
Shopety2012
Thanks, good info. Exactly what I was looking for.
Old 04-04-2014, 08:31 AM   #17
Def
A stock VVL head will still dominate over a mildly worked DET head from a performance standpoint. The shaft mounted rocker arms are just a side benefit. Having two cam profiles and tons of head flow is a huge jump in performance.
DEFSPORT
Old 04-04-2014, 08:34 AM   #18
Shopety2012
This wasn't a vvl head thread man. It's very easy to find the pros of a vvl head, threads are everywhere. This thread was because I wanted to know about what I now know is a dual guide conversion.
