![]() Join Date: Jul 2011
Pbm rear lower control arm s14 help
So I got my Pbm rlca with camber, toe, traction and the drop knuckle. the rlca looks to long even when all the way threaded in. Heim joint is maxed itself out towards subframe. Even under compression I have all arms as short as possible and it looks like I'm at positive camber a tiny bit or zero which is fine I want it zerod but there's no room for any camber adjustment if I wanted any negative. I think because the heim is maxed already.
Solvedd Last edited by KC224; 10-21-2016 at 11:53 PM.. |
![]() Join Date: Nov 2004
To go negative on a lower control arm that rod needs to come out.
Thus making the lower arm longer. That would give you more negative camber. I don't get what the problem is. Also, do you have adjustable rear upper control arms?
