![]() Join Date: Mar 2011
Need help on cluster light and tail lights not working
Fellow Zilvia memebers I need some help I tried searching not really sure if I am typing right thing but my tail lights and cluster lights don’t work brake lights are fine I herd there is a white box mybee fuse some where if someone can help Greatly appreciated
bust out the FSM and look for light circuit, hint - EL section. 'lights' and cluster lights are all on the same circuit, Red/Blue wire from COMBI SW to Fr and RR lights.
Do you have power at the switch? Do you have power at the fuse? how the heck can we magically figure out whats wrong.
@UpshiftEngineering |
It's in the turn signal stock. Disassemble the dash to get to it. And there is gonna be 5 copper strips on the stock and the middle one controls the cluster and rear lights. I pushed mine in a little and it works but over bumps it sometimes turns off.
