Need help with my 5speed swap
I did my 5 speed swap last week(5th one done)
I bought the clutch kit from Nissan And bought new master and slave cylinder Everything is right but my car won't go in gear When it's on, when it's off all the gears go in I adjested the clutch pedel to its max. I bleed it acouple times. I took everything off 4 times to check but does the same thang. If anyone can help pls. |
![]() Join Date: Feb 2012
Oem or aftermarket throw out bearing? I had an issue with an aftermarket very similar to this, it wouldn't completely disengage the clutch. Which seems to be your problem, or is the fork on the pivot properly? Is the fork moving in full range? I'm assuming you change the auto pilot bushing put of the back of the crank, and used a manual one as well?
Oem throwout bearing. I went too nissan and exganged it for a 96
Throw out bearing cause they are alot bigger. But does the same thing I swapped out the auto bearing for manual and fork works properly |
That's really odd....I wouldn't think internals, it still has to be clutch engagement. Used flywheel? Could be wrong but if its to thin and out of spec I believe it could cause symptoms like this? I'm just throwing out some more ideas. You adjusted the pedal which was my next thought....
I really appreciate. Pedal is adjested to the max.
Flywheel is good. Idk what it can be never ran into this. I didn't really wanna swap it but the auto tranny was leaking And I had all the 5speed parts Laying around |
![]() Join Date: Jun 2012
Check FSM on the Pedal Adjustment. Some Pedals are supposed to have slight play movement.
My Rx8 had this same issue before and the internals of the trans were melted together. My Second Rx8 also had this issue and I sold it without bothering to fix it again. I would try a new clutch kit and see what happens |
