Drift ready, but daily SRpowered coupe w/tails!
1989 Nissan 240sx base model coupe
Clean title in hand. has about 200xxx miles on chassis Vin# will be sent upon request. Engine -Redtop Sr20Det (maybe 50xxx miles on it. not completly sure) -Arp head studs -Greddy rocker arm stoppers -Cometic head gasket -Megan turbo manifold -Gt28r s15 turbo w/ AN oil line(with restrictor), and AN coolant in/out lines -s14 oil pick up -ebay turbo elbow -3" exhaust -custom mid mount intercooler set up -custom intake -turbo xs bov -koya radiator -ebay stage 3 6puck clutch -megan water pully -walboro 255 -SAFC note* I also have 550's, z32, and adjustable wastegate, that i am considering throwing in with a tune. but this isn't included. Interior -manual windows and doors -all interior intact. fairly clean -sunpro boost and water temp guages. -drift handle and button -tach and speed works no problem Exterior -has bmagic front bumper sideskirts -bmagic 50mm overfenders -gcorp smoked tail lights -leopard print hood! -painted in rattle can satin blue, which it came out nice *doesn't come with bike rack Suspension -HKS hypermax coilovers in front -TEIN basic coilovers in the rear. (rides great) -Ebay ruca and toe arms. alignment done to -1 camber in the rear -solid collars -comes with open diff -( has a steel plated welded diff in right now. If I'm to lazy to pull it out then ill let it go with it) Wheels -sport maxx 962's 18x8.5 in the front 18x9.5 in rear. -25mm spacers up front. needs a spacer in the rear to top it off the good Drives really smooth, and pretty quick for 6psi. compression is 160-165 across the board. Sounds pretty good. I love it but i need something more practical for school. Has power steering and heat(although heat is a little loud at full blast). I baby this blue bitch. Oil changed every 2-3k miles. the bad welded diff is way to cluncky for dailying. has no thermostat so takes a little while to warm up. Runs around 120* in this cold weather. And also over time it leaks a little oil from the side of the front cover. I would pull it off and reseal it but it is hardly noticeable. Overall I love this car. I put a lot of time and work into it. So if it doesn't sell then that's no problem with me. If you like it and want to check it out then i will give you a test drive. As of now ill take $5500obo. will take reasonable offers but i don't care enough to sell it so don't bother low balling. I will consider trades for gs3/400,sc3/400, 325i's. but no beat down shit. I want something more factory. Im located in Georgia near Mcdonough to stockbridge area Any questions text or call me on my cell. 404-603-6149 Matt Geo |
| coupe-ness, madness, smoked, tailights |
