![]() Join Date: Jan 2008
![]() ![]() ![]() Feedback Score: 6 reviews
fuel pump prob?!?!?
S14 SR20det redtop
i checked all the relays and fuses on the car and they all worked fine i took out the fuel pump and i tested it with a battery and it worked fine i put evrything back together and my car wont start. so far what i noticed is that i have no power going to the fuel pump cuzwhen i turn the power on the fuel pump wont turn on for a sec as it should once agin im clueless all the relays and fuses r fine but when i checked the power plug from the fuel pump my test light shows theres no power going to it at all so does anybody have an idea y its doing that? THANKS A LOT FOR THOSE WHO R HELPING ME! |
![]() Join Date: Jun 2004
Trader Rating: (73)
Try using a different ECU, or making sure your ECU is plugged in tight.
I had a bad ECU and my fuel pump wouldn't prime.
