![]() Join Date: May 2009
Hey guys i've decided to call it quits with my build and decided to sell everything, this is a list of some of the things i have for sale, everything is obo so hit me up if you see something you want. ill try to get pics up soon.
KA24DE: KNIFE EDGE CRANK, EAGLE RODS, CP PISTONS, STAGE 2 BC CAMS, BC VALVE SPRINGS AND TITANIUM RETAINERS, ARP MAIN STUDS AND HEAD STUDS. $1500 AEM EMS: WITH MAP SENSOR, AIR TEMP SENSOR AND TURBO SOLENOID. $1,000 GARRETT TURBO: T3T4 57 TRIM .63A/R$550 Z32 BRAKE CONVERSION: WITH Z32 MASTER CYLINDER, 4 CALIPERS, BRAKE LINES, FRONT SLOTTED ROTORS, E-BRAKE CABLES $500 5 LUG CONVERSION: ICHIBA FRONT HUBS, REAR Z32 HUB WITH ALUMINUM UPRIGHTS $500 CARBON FIBER HATCH: $450 TANABE STRUT BARS: FRONT AND REAR WITH BLACK HATCH HIGH MOUNT BAR $150 DARK BLUE SPARCO SEAT: COMES WITH BRIDE RAILS $550 S15 PASSANGER SEAT: DARK BLUE, NO RIPS $200 POLYURETHANE MOUNTS: ENGINE AND TRANS MOUNTS $150 Z32 LSD: DIFF WITH 5 BOLT AXLES $350 RIMS W/ NEW TIRES: 2 PIECE ALUMINUM 2” FRONT LIP 3” REAR LIP, FRONT TIRE 245/45R17 REAR 275/45R17 $1,000 INNER & OUTER TIE RODS: TIEN $100 INTERCOOLER KIT: $140 TIAL WASTEGATE: 38MM $180 SARD 800CC INJECTORS: 4 BRAND NEW $500 TOP FEED FUEL RAIL: BRAND NEW $150 RADIATOR W/ FAN $260 FUEL PUMP: HIGH FLOW 225 HONDA PUMP $120 Q45 THROTTLE BODY $70 Z32 MAF $70 SARD BLOW OFF VALVE: RETURN TO PIPPING NOT ATMOSPHERE, REDUCES TURBO LAG $380 NOS KIT: 80 SHOT CURRENTLY ON NOZZLE, HAVE JETS FOR 100 SHOT AND HIGHER $ 300 DASHBOARD: BLACK, CLEAN NO RIPS, $100 DOOR PANELS: black with custom blue insert $100 CARPET: BLACK CUSTOM CARPET $150 HEADLINER: DARK BLUE $80 BATTERY RELOCATION KIT $100 SR 3” MEGAN DOWNPIPE $60 |
#22 |
mounts are from jgs and are the polyurethane so they are very stiff, shipping is available if you pay for shipping, the fan i have on right now is a 16" single extreme duty fan that i got from Kragen and make brackets for it so it sits perfectly center to the radiator
