![]() Join Date: Dec 2008
SR20 DET rebuilt - can I use s20DE rering kit?
I cannot find an SR20DET rering kit. Through research I have found that the DE and DET piston rings are the same - my maing question is if the connection rod bearings are the same. I really only need the rod bearings and rings, the gaskets arent such a big deal. Im looking for a cheap rebuild kit.
here are some I found - sr20 rering kit - Google Product Search again, are the rod bearings the same between an sr20de and det? Cheers, Dave |
