#32 | |
![]() Join Date: Feb 2012
#33 |
Correct sir! On side note wastegate failed withing 5 seconds. Not sure if it was defective but its stuck open. Removed spring and valve will get stuck and I had to tap it to get it.loose. removed, junked, used my tial mv-s=problem solved
#34 |
![]() Join Date: Apr 2004
Can you post the dyno up?
I saw the thread blow up over on SXOC - some of those guys are a little unnecessarily cocky... But you posted you made near 500 rwhp, so I'd love to see the graph. Also what boost and housing A/R are you running? This is giving me hope a GTX3071R will still work out for a reasonably responsive track setup.
#35 |
Apologies for the delay on this was doing some more twin scroll reading and bumped into this old thread. The dyno is in this thread on sxoc. http://www.sxoc.com/vbb/showthread.p...-tra-kyoto-s13
Couple of pages from the end |
#37 |
![]() Join Date: Oct 2008
Just wanted to post because people were doubting the fact of stock cams
Stock block,bottom end, head,cams, exhaust manifold Freddy intake 1000cc bosh injectors @60psi base pressure Walbro 400lph pump Power fc djectro E85 Arp headstuds Cosworth hg Tial 38mm vband external wastegate Greddy 20g At 22.4psi I made 470whp 417wtq ![]()
