#961 |
well guys, im getting the Greddy intake mani, new fuel pump,thicker hot side piping, and water/meth kit installed as we speak! muahaha!!! i will get a tune on sunday n see what we put out
want to be in the 500whp club by the end of next year!!! |
#962 |
![]() Join Date: Aug 2007
So, I just got my 2871 .64 back from my Garrett dealer. Apparently the previous owner of it, who only used it in 8 events, had something go through his exhaust manifold which chipped up every single blade on the exhaust wheel. The rad thing about it that is Garrett has a "cartridge replacement program" wherein they replace the entire cartridge for $370.00. I got the previous owner (a friend of mine) to pay for it, since he had told me the turbo was in tip-top shape. Sooo.. I basically have a brand new turbo, minus housings, and actually the exhaust housing just came back from Jet Hot too, so it's better than new.
Got some Tomei 260 Poncams, 850cc Sard injectors, and Tomei valve springs to throw at the set-up as well. Looking for 350whp, daily driven, on as little boost as possible. Tune to come in the next month or so.. |
#964 |
So, i got her tuned n we tried to push 18psi but the wastegate wouldnt hold boost and would only boost 16psi and spike to 17 at one point.
Even with that issue i put down 381whp and 303trq with power holding until my 7600 redline. i wish the trq was a little higher but its still great for only 16psi!!! lol im working on going external and running 20psi with water/alcohol. also, one last note. this was done on a dynojet but the funny thing is that it put down 325whp on a dynodynamics dyno at 12psi and when i took to these guys to get tuned we did a base run at the same level and it actually read lower than the DD Dyno. funny? yeah i thought so too. oh well now that i have a good tune a review of the tuner and fuck ups of the previouse tuner will be posted. Mods so far are: S14 SR20 HKS 256/264 10.5mm cams apexi HG (stock thickness) 740cc inj circuit sports fuel pump z32 MAFS 2871r .64 52trim New design GReddy intake Mani MR Ex. Mani AEM water kit
#966 |
I got it tuned by paul bischoff and reggie @ OSR. good peoples. he actually tuned directly from the handheld which i thought was crazy but he's been at this for over 15 years and caught the mistakes that were made before and figured out why the other tuner couldnt go past 12psi without seeing detonation.
#967 |
Those are badass numbers.
My set-up is pretty common to yours and I'm expecting similar numbers. I will be running an ethonol/fuel mixture pretty much all the time, although I'm running both of my manifolds stock. We shall see soon. ![]() |
#968 | |
![]() Join Date: May 2008
(OΞO/- -\OΞO) |
#969 |
yeah, im sure that with the fuel mixture you're going to run the tuner will be able to play more with the timing and boost! you should be driving a beast!! I imagine that with the stock mani's the responce should be insane.
#970 |
i dont know how they used to tune but the power fc tuning they did was on point. im going back for a retune after i change my WG
#971 | |
You stated that you're replacing the gate. Your 2871 is internally gated, correct? |
#972 |
![]() Join Date: Sep 2008
ok guys heres what im going to be running
s13 sr20det cp pistons 86.5 eagle h beam rods apexi hg 1mm oversize valves bc springs and retainers hks 264 cams hks cam gears greddy version 2 intake mani tomei tb tomei manifold gt2871r .86 apexi pfc exedy hyper stage single balanced crank new oil pump new water pump s14 water neck 740cc nismo nismo fpr new timing chain i know theres more but i cant remember off the top of my head what do u think ill be pulling with these parts |
#973 | |
I think this will fit on the new housing, I switched from the tomei bottom mount to a peakboost top mount, and used this wastegate with about 1.5" of space from tp[ of the wastegate to the shock tower. I would like to see how this application will turn out on a decently built SR. |
#974 | |
![]() Join Date: Aug 2005
Trader Rating: (60)
![]() Feedback Score: 60 reviews
And why are you buying all these parts and only running a 2871r. With everything built, you should be running a gt30. 2871r is a waste with your engine build. |
#976 |
![]() Join Date: Sep 2005
whats up fellas? i wasnt about to browse through the entire 33 pages of this sweet topic. although, im sure there are a few people with the exact same setup i have.
here it is so far: sr red top bored .020 over cometic 1.1 head gasket greddy intake manifold hks 264 step 2 intake and exhaust 2871rs .64ar port and polish head ferrea valves titanium valve springs and retainers greddy front mount v-spl titek denso 850cc injectors apexi afc enthalpy tuned ecu equal length manifold(i was told its titanium as well, but i highly dout it is)(bastard mechanic) walboro 255 all parts are installed and im waiting to get my intercooler back. had a few small holes in it. once i get it all back im looking to get it on the dyno and tuned as well. i guess im shooting for approx. 350ish at the wheels. what do u think? am i on track for that or no? i also would love to have a external WG but there is no room. i was thinking about that slim one just mounted on the downpipe or something. if i weld the internal flap shut then it shouldnt be an issue. i will say there are some very impressive numbers on these setups. Jay |
#977 |
Trader Rating: (60)
You will hit 350 pretty easily. I talked to a guy with a s13 sr this weekend and he said he was only running a safc on his 2871r setup. He was pushing around 370-380. He definately could back it up because he was running mid to high 7's consistantly in his s13 with slicks.
#978 | |
![]() Join Date: Dec 2006
I find it hard to believe he runs 7's in the 1/4 mile seeing that mine runs low 12's on street tires
#980 | |
I've met some dumb ass people that talk out there ass that think they know what they are talking about. (not saying you are)
#981 | |
![]() anyway, thats for the info guys. |
#982 | |
#983 |
man, i wouldnt mind taking my car to the track but there arent any 1/4 mile tracks around...only 1/8s
#984 | |
#985 | |
I have yet to run the ethanol/fuel mixture as of yet. I'm currently running a ProEFI engine managmnt. Running this unit, in conjunction with a GM fuel pressure sensor (from the flexfuel vehicles) will allow me to run different fuel mixtures. They're already doing this with 2jz-gte Supra's on this computer, but I will be the first do so with an SR! To me, this is the best of both worlds, as I won't have to rely solely on pump or ethanol and can run more aggressive timing, all the while enjoying the protection that higher octane provides. |
#986 | |
#987 | |
GL w/ the set-up regardless, and get home in 1 piece! |
#988 |
i know norm im just looking for a little information and ive read all these pages before so i was just wondering what my numbers should be and i all i get it smart ass comments
#989 | |
#990 | |
