![]() Join Date: Jun 2005
how to get rid of the SPEED LIMITER on a s13 SR20.
i wanna know if there is any way i can get rid of the speed limiter on my redtop without having to buy a SLD. is there a wire i cut or any home made way of doing it.
There is a way to unplug some of the sensors on the tranny that will eliminate the speed limiter. I can't remember which I believe it is 4th and 5th gear, but not sure will have to look at my boss's to be sure. I will get back to you on this as soon as i can.
back at it again.... |
![]() Join Date: Mar 2004
Reprogram the factory ECU.
R/T Tuning |
![]() Join Date: Sep 2005
I unplugged the sensors on the tranny(not speed sensor) then unplugged wire on ecu.
Did nothing for me, so i hooked up the tranny sensors limiter kicked in at 4500 rpm. So then, I plugged back in the ecu wire reset the ecu. Now! I don't know were the limiter is, NOT 4th gear 125, nor is it at 5th gear 5500rpm. And i still have speedo how cool is that. Still I guess it's better knowing where your limiter is........... so you don't hit it.
![]() Join Date: Dec 2002
Jesus, is this 1991? Talk about a time warp from hell.
Cut the VSS and 5th gear switches at the ECU. Done. Better yet, install a DPDT switch in line so you can cut the circuit when needed, saving a CEL. And seriously, this was the first thing I ever read on the internet when it was created. You guys need to start over in life if you haven't found it yet.
#11 | |
![]() Join Date: Nov 2004
someone please clarify! |
Vehicle speed sensor. Please, for the love of God, download an FSM and read it.
#13 | |
What is FSM?
Factory Service Manual Quote:
I have an anomaly. No one can explain why I still have speedo, I think i may have fried that circuit.
![]() Join Date: May 2003
^^^ Cut it at the ECU...it goes to the speedo first, then the ECU.
Speedo still works, but ECU sees no speed signal. Easy. - Brian
www.KA24DEvelopment.com |
#17 | |
![]() Join Date: Jan 2004
get the JWT tuned ECU from me for blacktop s13 sr20det, Speed limitor removed. supports 555cc injecters and z32 maf. 350 OBO
96 all suspension s14 SOLD 90 s13 coupe - SOLD Currently rocking 2002 BMW M3 w/ custom suspension. ![]() ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only. |
#20 | |
#21 |
How about you get off your lazy ass and check the FSM pinout. Or would you prefer someone to fly out and do it for you?
#22 | |
#24 | |
Factory Service Manuals |
#25 |
Figures. Kids from San Diego are too busy eating D to worry about FSMs.
#26 |
![]() Join Date: Jun 2004
heres how to do it WITHOUT spending tons of cash on speed limiter removal bullshit.
1) get under the car, cut the power wire to the speed sensor. its the red one. 2) now, get a wire to run into the cabin, wire in a switch and put it somewhere for easy access inside. 3) get back under and wire it up. now, when u wanna race - pull the switch and guess what? no speedlimit. total cost= 10 bux max. ur ecu cant read speed output so there is no limit. works great for me.
hydropgrahics! ![]() ls1...... |
#27 | |
That's three times the work as cutting inside, plus you lose your speedometer. Cutting it inside takes less time, requires less wire run, and keeps the cluster intact.
#28 |
^either way that works for you. i just dont like cuttin pigtail wires. its just personal preference really. but yea, ur way is better.
#29 |
hehehe check the speedo...
