![]() Join Date: Jul 2005
Trader Rating: (354)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 354 reviews
If interested please PM me or leave a reply here.
I am located in Riverside/San Bernardino Socal area. S-Chassis Eccentric Lockout Kit -Get an alignment and be done with it. Remove those stock eccentric bolts that get out of alignment. -Grade 10.9 Zinc Coated Metric Hardware -Washers are Laser Cut to ensure quality -Mild Steel Washers give the option of welding onto subframe, or paint them to prevent rust. -Comes with 4 Grade 10.9 Zinc Coated Bolts, 4 Lock nuts, and 4 laser cut mild steel washers. Price:$48 or $52 shipped S13 to Z32 2+2 E-Brake Brackets -Make your Z32 2+2 ebrake cables bolt on to a S13 -Comes with all the hardware Price: $48 / $52 Shipped S13 JIC Inner Tie Rods -Look to be JIC. S13 Thread pitch on the out end(12mm vs. S14 14mm) -Built in Steering rack spacer -3 threads shorter than a S14 Tie Rod but thread runs in deeper -Comes with dust boots Price:$90 shipped Comparison next to a Moog S14 Tie Rod SR20DET Ignitor Chips -Both tested and work! -Works on both S13/S14 SR Motors Price: $30 / $35 Each Shipped 180sx Kouki FRP Front Lip Made from high quality fiberglass material. Easily flexible and made to fit perfect. No hardware or double sided tape is included. Made in the U.S.A!!! Will come unpainted in a black color rather than the white that's also shown! Price: $180 / $220 shipped within the lower 48 U.S. states *Pictures show lip attached to the bumper with NO hardware or double sided tape installed!!!* |
