Hi
I have ran into a issue with my Nissan 240SX, it's automatic, the Overdrive Lockout Switch Gear Shifter Button is not staying in and only stay up? I think the spring is broken? I called dealer and they said they don't have that part. When I am driving it and I press the button it does work and shifts but the button just doesn't stay down. I looked on Ebay and found only the shifter, does anyone have a suggestion here? I really appreciate your feedback on how to fix this? thanks B |
Unless I'm mistaken, the fucking button is pointless. My Silvia's shifter will move even with a the functioning button.
I'd save the money and just not bump it lol.
![]() Join Date: Dec 2011
The button prevents the tans from going into overdrive when activated. If you never have any use to block it then you don't need it.
Have a great day. Hell you could even wire in your own switch if you are hell bent on doing it. Have a great day, jared |
| overdrive shifter button |
