Hi guys, I have an S13 with an SR and a Power FC and it won't start at all. I am wondering if you can offer some advice on where to start to diagnose what is wrong with my car
![]() I have verified the fuel pump is kicking on and my power FC is turning on but still no go when i turn the key. Any clues as to what I can check next? I have a DMM so I can check connections just not sure what I'm looking for exactly. |
Did it start before you installed the power fc? But do the basics like hook up a fuel pressure gauge inline after the fuel filter and before the fuel rail and make sure your getting the 43psi i beleive and then hook up one of the spark plug testers to make sure it's getting spark..also a compression test.one of those is off and you can continue the diag
Instagram username:angelmkiv |
yes it was running great, it had a fresh tune and was dialed in. Then one day I turned the key and all the magic disappeared from our relationship
ok I'll check Fuel pressure and spark and get back to you. Thanks for your help! |
When you say turn the key over you mean during cranking right? But double check the coilpack harness ground wire/ignitor chip plugged in and all connectors are tight.. Then test to see if the coils are getting power and work your way back
| 240sx, powerfc, problems, sr20 |
