![]() Join Date: May 2005
Blitz Turbo Timer Install...help
I just need to know if someone can help me out with something. I have the Blitz DTT-DCII. I bought the wire harness for it so it would be easy plug and play. The thing is that there is a purple wire that is not on the harness, but on the main control box instead. There is also a hollow line which I am assuming is for the built in boost guage. I need to know what the purple wire is for, and where EXACTLY it connects under the dash. Also, if someone can tell me what connector to look for to get the TT harness plugged in that would be great. Thanks.
I can post a pic of the TT unit if that would help.
'93 Coupe BlkTp-SR '07 Chevy HHR - DD |
I dont have a wiring diagram. I lost contact with the person I bought it from. It's just strange cuz the purple wire is all by itself....just chillin. Could it be a nuetral safety switch, or something that hooks to the e-brake? I have searched for a diagram, but they always are in japanese. The actual model is the DTT-DCII. I will post a pic when my roommate emails it to me.
![]() Join Date: Apr 2004
If it's the handbrake switch, you can just ground it and it will think the handbrake is engaged. That will get you running until you can correctly wire it to the handbrake wire.
yeah, I talked to a few people and they all said those were options. Either splice it into the e-brake wire (pink??) or just ground it out. I would much rather just hook it up right and splice the bish into the e-brake.
#9 | |
So it's okay for track use. |
