Vibration between 2000 and 2500 rpm
I recently changed my clutch flywheel and transmission. I now have a vibration from 2000 to 2500 rpm. I have looked called searched and tried everything. To find out what the issue is. It's a spec stage 3+ with a spec billet steel cnc machined balanced flywheel. And I have this issue I installed everything correctly and torqued all bolts to spec it happens whether free revving, clutch in or out and while driving. I have no clue what it is. Any help would be appreciated.
1993 240sx coupe
1995 Sr20det notch top
