Custom Intake Manifold Injectors? Help
So I have a ka24de custom intake manifold and I need to know what kind of injectors should I install in them.
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting |
![]() Join Date: Dec 2008
Your gonna need top feed fuel injectors.
Look into getting some RC Engineering ones. Is this going to be ka-t?
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
You need to measure the ID of the lower seat and upper seats. You'll have to figure it out from there. They are probably standard Bosch style injectors which you can get anywhere. RC's have that style injector.
My SR20VET |
And if your on a budget you can get some 680cc injectors from the first generation gsl-se rx-7.
Thanks Everybody. The only reason I asked is because my stock sr20 injectors didn't fit. They were too short or stubby. However you wanna call it and it didn't sit well.
They wouldn't have worked even if they fit since they are side feed injectors.
Like JuMPiiN said. But for the fpr if your only going for a stockie like sr setup an adjustable fpr won't be necessary. You will need a rom tune however. Also make sure to get a walbro pump if you don't already have one.
You're best bet being that you're 17, sell the manifold and keep your stock one. You don't have the funds to build a high hp setup that this manifold would accel on anyway...
My SR20VET |
