![]() Join Date: Sep 2009
Slave cylinder installation
How do you relieve the pressure off of the slave cylinder? I took the old one off, which was busted. I went to put the new one on but the little pushrod acts like it's .25 of an inch too long for what ever reason. I can't figure out how to pull back on the clutch lever to get the slave cylinder bolts started. What's the secret? Thanks in advance.
![]() Join Date: Dec 2006
sometimes you have the aftermarket part that is not exactly the same as oem. if u tried compressing the slave already and it still doesnt fit, then look at the old slave and see if the rods are different sizes if so try taking the old one off and put that on the new slave.
