![]() Join Date: Feb 2002
Enjuku Racing - *OPEN BOX CLEARANCE* ISIS Performance Suspension arms 240sx/300zx
ISIS Performance Rear Toe Rods/ Front Tension Rods/ Rear Traction Rods *Open Box Clearance!* In Stock and Ready to Ship! ISIS PERFORMANCE REAR TOE RODS - NISSAN 240SX - $70.99 ![]() ISIS Performance Rear Toe Control Rods - Nissan 240sx 89-98. These are a must when lowering your 240sx. Should be replaced when you do your rear camber arms as well, these toe rods enable you to correct toe angle and save tire wear. Despite what most people think, incorrect TOE will wear tires MUCH faster than camber will. Same Arms as used on the Enjuku Racing Professional Formula D Cars. Item sold as is Item has scratches and chips on the paint due to shipping Never installed or mounted ISIS PERFORMANCE FRONT TENSION RODS - NISSAN 240SX - $77.99 ISIS Performance tension rods for 95-98 240SX. Allows adjustability of caster High quality rod end. Direct bolt on. Same Arms as used on the Enjuku Racing Professional Formula D Cars. Sold as is Item has scratches and chips on the paint due to shipping Never install or mounted ISIS Performance Rear Traction Rods - Nissan 300zx Z32 1990-96 - $69.99 ![]() The last piece to be replaced in your 300zx rear multi-link, this rear traction link enables you to reduce bumpsteer and wheel hop. Same Arms as used on the Enjuku Racing Professional Formula D Cars. Item sold as is Item has scratches and chips on the paint due to shipping Never installed or mounted
