Parts Shop MAX ~Engine Vitals Digital Meter~ O.LED Temp+Pressure+Volts FREE shipping
New EVDM meter debut for 2011 - EGT (exhaust gas temp) + RPM + VOLTS all in one is in stock now! $180 shipped
0-1100 degrees C 32-2012 degrees F 0-12,000 RPM ![]() ![]() We are proud to debut our MAX EVDM Engine Vitals Digital Meter! PURCHASES AND SHIPPING QUOTES DIRECTLY FROM THIS THREAD! SIMPLY CLICK THE BLUE ADD TO CART LINK VIEW CART EVDM $180 Free worldwide shipping! CLICK HERE TO ADD TO CART & ORDER ONLINE In stock NOW! ...and its awesome! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Stop trusting that inaccurate 20 year old OEM water temp sensor with your engine life. We give you a high tech solution to monitor all of your most vital data - Pressure, Temp & Volts on a brilliant organic LED display which is easy to install on the surface of your dash, and easy to wire up. Price is $180 with free priority global shipping. This includes the OLED screen, English instructions, 1 year warranty, Wire harness, Temp and Pressure sensors. EVDM $180 Free worldwide shipping! CLICK HERE TO ADD TO CART & ORDER ONLINE In stock NOW! You can also double your information by purchasing two digital meter kits so you can display ~ Water Temp ~ Oil Pressure ~ Oil Temp ~ Fuel Pressure ~ Volts ... at the same time on your dash. We also sell the oil filter re-locator fittings kit whose engine block adapter features two sensor ports for pressure and temp $60 and we also offer the water temp radiator hose adapter for $20 and a fuel hose adapter for $20 as well to get you up and running quickly. These items can also ship for free when you purchase the digital meter at the same time, we'll throw them in the same box. ![]() Instructions: ![]() ![]() VIEW CART
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 01-03-2011 at 06:40 PM.. |
Exactly, thats the essential combo everyone should have on display in their car, and we offer this on one screen with the new EVDM.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
Steve - you can get it in Japan but Eisuke-San charges shipping and I dont, so buy from me - lol
For Sure, we're really stoked about this
We did our homework and there is no better choice, it's the dual screen or full color for a lot more money, larger case and ground up redevelopment, then you get to choose any color. We thought its not worth it to compete with the elite japanese brands that have full color and cost big bucks but this high resolution and brightness OLED beats the pants off the old school segmented display on the Yashio Factory Okachan water gauge for less money.
It's not designed to match your car's illumination but instead it's meant to catch attention as a stand alone device.
![]() Join Date: Apr 2006
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Will the oil pressure sensor thread into the tomei oil pan?
Where do you suggest threading in the coolant temp sensor? Looks like a great product! Intriguing to me because I don't want to put more gages inside my car!
The sensors are 1/8" pipe thread.
I suggest our $20 radiator hose adapter for coolant temp.
#13 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
Awesome! I'm glad to see PBM starting to make stuff like this! I might have to pick one of these up. Much better than buying multiple gauges!
I <3 PBM.
#17 |
You can have 1 pressure and 1 temp plus volt on one meter so two things are optional volt is not.
So you choose oil or fuel pressure for the gauges first channel and then water or oil temp for the second channel. So if you want to display 3-4 sensors plus volts you need 2 gauges. Fittings are 1/8" pipe and viewable diagonal is 28mm
Interested, but the only thing is the screen size. Being a lil more than 1 in diagonally and displaying 2 sensors, is not much of a display. Would you say its still viewable if mounted in the DIN pocket underneath the radio (S14)?
#20 | |
![]() Join Date: Oct 2004
So are these sensors BSPT that are included or NPT? Thanks!
Turn and Burn!
#22 |
You can switch the display to monitor one sensor that is your biggest concern in larger numbers and there is the yellow bar graph with your preset warning limits that is easy to glance at without even reading the number. Also the illumination and resolution is brilliant being more readable than analog gauges while driving. The numbers are about the same size as analog gauge fonts, just brighter. Bottom line is you have to see it in person to judge it. I'll post a you tube video of the guage as soon as the stock arrives.
On my computer the "switchable display" screenshots are about 50% of actual size. All of the images in the OP are photos of the screen. Below is a bitmap of the screen pixels in web resolution (72DPI) so that you can reference the size and resolution against other elements on your computer screen. ![]() We are planning to ship 1/8PT-28 that matches commonly available sensor adapters in Japan to the Japanese market, and we are planning to supply 1/8NPT-27 to the USA market to match the commonly available sensor adapters in the USA. The MAX Oil and Water adapter fittings that we have been selling in the USA for years now already are 1/8NPT-27. Its supposed to supplement not replace the OEM sensors and gauges.
#24 | |
At about $260USD ![]() And we're not trying to be the end all be all gauge to compete with this: At about $490USD The thing is there is fancy stuff from Greddy and Blitz for more money so that segment of the market is well taken care of, and therefore seems like no need for us there. The MAX EVDM at $180 shipped seemed to be a better fit for this community, am I wrong about that? Yes exactly, independant user set limits warn you about both sensors.
#25 |
function over fashion this is TITS!!
ive spent over 400 on oil pressure oil temp and water temp from greddy. i could've saved a lot of money by going with this back in the day. |
#27 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
So you can only monitor three things with this? Dan, you were saying something like Ch1 can only view pressure related stuff, ch.2 can only do temp type items and of course voltage.
So you couldn't view oil pressure & temp, fuel pressure, water temp, and voltage all AT THE SAME time right? |
#28 | |
As I see it, It's perfect because it'll slide right into 1 din radio pocket. Looks like the words will be same size as an Apexi SAFC2. When I know for sure my oil pan thread I'll post info to you Dan as well as probable order lol.
#29 |
You can monitor two sensors at the same time + volts per gauge (each meter comes with 1 temp and 1 pressure sender)
You could view 4 sensors at the same time with two MAX EVDM's
#30 | ||
Any pictures of the actual display will be appreciated when you get them. Quote:
