FS 2001 Lexus LS430 $8000
Super clean. 122,000 miles.
$8000 https://i.ibb.co/BgjczDV/IMG-0459.jpg https://i.ibb.co/F0Pjq8s/IMG-0469.jpg https://i.ibb.co/Km9mD0r/IMG-0465.jpg https://i.ibb.co/ZS8jB4z/IMG-0472.jpg https://i.ibb.co/tZ1SMGv/IMG-0466.jpg https://i.ibb.co/sm81R5F/IMG-0467.jpg Located in Indianapolis, north side. I've owned it for a little over a year. 99% of it's life it was owned by an older gentleman in Florida. The past 12 months the following has been replaced... Timing belt / water pump Radiator Battery Drive belt Air filter Cabin filter Spark plugs Transmission flushed and new filter New synthetic diff fluid Rotors pads calipers and hoses all around New brake booster and master cylinder Front and rear sway bar end links Polyurethane front and rear sway bar bushings Daizen tuning polyurethane steering rack bushings Both inner and outer tie rods Both front lower ball joints 25mm bolt on spacer up front Parts Shop Max adjustable rear spacers BC RACING coilovers with swift springs Youzealand SS kit in rear Amistad Grace wheels 19x8.5 19x9.5 New Federal Evoluzione tires all around New rear deck 8 inch subwoofer Paint polish/correction by Pristine Auto Spa Headlights covered with Xpel film All interior lights and puddle lights replaced with LED units 6k HID and 6k LED fog lights Contact: [email protected] or PM on here Thanks! Last edited by Hondamatic; 06-04-2019 at 07:27 PM.. |
![]() Join Date: Jan 2010
is this the UL model? its hard to read the badge on the fender. excellent deal either way. i was looking at these prior to buying my IS300 and they were all 10k+.
![]() Join Date: Oct 2004
emceetickles bumps
Drift Indy |
