| South Western States Arizona, California, Hawaii, and Nevada. |
![]() Join Date: May 2008
Computer Overclock service?
Hi,
Just traded my laptop for a new computer, just wondering are there any services in LA 626 area that can help me overclock my cpu and gpu? Here are the specs. 1. Q6600 Core 2 Quad 2.4ghz Kentsfield (Top seller) 2. EVGA 780i Sli Ready motherboard (Top seller) 3. BFG 9800GTX 512mb Graphics card (Sli) 4. 64Bit Home Vista 5. Antec 900 Case (Top seller) 6. Antec 650watts Earthwatts Power Supply. 7. Samsung 750GB 7200 Hard Drive 8. 20x DVD-R CD-R Drive 9. 4gb Kingston DDR2 1066 (PC2 8500) 10.Zalman CNPS9700 LED CPU Cooler (Blue lighting to match the motherboard) |
thats a pretty beefy setup you got there.
ive never really seen any "services" that overclock your pc for you. your best bet would be to start reading up on computer forums such as overclock.net and start off slow. always remember to use stability tests and never make huge increases in voltages and bus speeds at one time. monitoring temperature is also a must, you must keep you temps within spec so everything will be running safely. programs you should use: stability tests: prime 95 temperature monitoring: HW monitor, core temp general information about your pc: cpuz its nice to see another zilvian who is interested in overclocking. my specs: cpu: amd athlon 64 x2 5000+ black edition 2.6Ghz @ 3.2Ghz mobo: asus m3a32-mvp deluxe motherboard gpu: visiontek ati 3870 OC 512mb psu: antec ea650 ram: 2gb crucial ballistix @ 800Mhz hd: WD 320aaks os: xp pro/ windows 7 |
#4 | |
![]() Join Date: Jun 2008
A+ won't help you much with anything past xp or any type of overclocking on brand new hardware. I would recommend checking out overclockers.com and tomshardware.com and any other hacking/modding/pc performance site to learn how to do it. I have yet to overclock a new proc but I remember the days of overclocking thunderbirds using a pencil. |
