#151 | |
![]() Join Date: Mar 2014
~755whp 1jz.~ Proefi 128, e85, 1200cc, 6265, 39psi |
#152 |
I just went down to the local Driveshaft place and told them the length and what trans and diff. made it more us.
#153 |
![]() Join Date: Sep 2012
What intercooler piping did you get as 'cores' if that makes sense. From what i've been reading mkiv piping and sr20 core should work great but who knows. and more info on that tasty cooling setup...mmmm.
#156 | |
S14 1jz Brother build
Sweet deal! What exhaust housing did you go with? I will be interested to see the results as there are not a lot of GTW data out there, esp on the JZ platforms
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
#157 | |
we got the manifold mocked up, I tack weled the Tial on, and cut and tacked a 90 degree elbow on for outlet. Also mocked up downpipe. Now just need to run and install the oil lines.
