![]() Join Date: Nov 2008
The Ballin on a budget s13 build
So I got this car in a trade plus cash for my 350z.
Basic info on the car when I got it Blacktop s13 sr ,wiring specialties Stance gr + coils Solid subframe and diff bushings Pbm ruca's and toe arms Aftermarket sway bars Solid motor and trans mounts 1 piece driveshaft Greedy fmic Megan turbo manifold Spec stage 3 clutch ISIS blast pipe exhaust Aem tru boost, and oil temp Guages I took it to an event ended up rod knocking the motor. Since then I've been working deal after deal. Ended up getting a built redtop cp pistons,eagle rods, bc 264's and springs. The bad thing is the block was damaged but the pistons weren't hurt. So we're going to put everything in the rodknocked block after a trip to the machine shop The motor came with a Trans spec stage 4 clutch and flywheel cx racing top mount t3 / t4 turbo manifold, wiring specialities s13 sr into s14 chassis harness, greedy knock off intake and oil pan. A friend of mine wrecked his caged hatch and got a new caged shell to swap his drive train into he cut the car up and sold me the cage pretty cheap since I'm helping him get his 1j s13 coupe running Cost breakdown Built sr and extra parts $700 Cage $300 Parts sold Spec clutch and flywheel $ 600 Codyace ac, ps ,and alt. Brackets $155 Total out of pocket into the build atm $245. Built sr with damaged block Cage out of the other car Cage cut and mocked up Electric sunroof taken out taking It to get the cage welded in by a family friend. Using the plasma cutter to cut holes to drop the cage down to weld the tops Cage welded up (still need to build door bars once I get a permanent seat) |
