Old 04-23-2008, 09:09 PM   #1
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
s14 sr no start
s14 sr. stock with bolt ons. will crank and turn over but won't fire up.
have fuel. no spark.
checked cas, coilpacks, ignitor, ecu. no spark. which leads to bad ground in wire harness??
i'm pretty sure that's what it is but how do you check that?? my friend checked it for me before and we actually found it. hooked up a jumper wire to ground it and it worked. got the car running
2 days after it wouldn't start up again with the same problems. my question is how do you find bad grounds in the harness or what else could it be??
p.s. the car was running perfect bbefore on teh wc ecu, the new ecu i got is a we. do i need to do anyhting for that to work or will it fire right up?
slideways2004 is offline   Reply With Quote
Old 04-23-2008, 09:29 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
gimme a call at the shop tomorrow when you're standing by your car with tools in hand
Dave @ Lethal Injection Motorsports
RB25 280z GT30/76R 441hp/381tq [email protected]
Z U L8R is offline   Reply With Quote
