240sx fuse box question
I have been searching all day and can't seem to get a definite answer. Was wondering if a base model fuse box with no alarm/anti theft relays could be used on a 240sx that has OEM alarm. Would car still start or do those relays connect to a starter inhibitor?
Thanks for any help |
Hey thanks for the reply... I currently have the fuse box installed and car will not start. I have test everything and have found that I am not getting a 12v signal to starter. I can stick a wire to the back of the key switch straight to starter and it will start fine...all fuses have been checked and in the process of checking relays.
![]() Join Date: Feb 2012
Trader Rating: (37)
On s13s, when you covert from auto to manual, there are a couple of wires that need to be overridden in order for the car to fire up. Not sure about the s14s. Something that you might want to search on.
Your new to you harness, was it from an auto or manual?
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
