12-26-2013, 07:26 PM | #1 |
Redtop Sr20det iacv HELP !
Nooby question but ive been putting my sr20det together and I bought it missing a bunch of stuff. Im almost done but I cant find out a write up or diagram of where or how to connect the Iacv and other intake manifold hoses. Please bare with me, ive searched and searched but couldnt find what I needed. Pictures of where the hoses connect to would be much appreciated.
And Everything is OEM. Sent from my SGH-T999 using Tapatalk |
12-26-2013, 10:04 PM | #2 |
I deleted mine but this are the the best pics I can find for you.
BTW search NOOB. http://zilvia.net/f/tech-talk/303543...lant-line.html |
12-26-2013, 10:08 PM | #3 |
Well like I said about ^ I searched and searched. I have everything hooked up except my IACV and the like one line on the intake. The link was just of the heater hoses and turbo lines. Im not that much a noob.
12-26-2013, 11:26 PM | #4 | |
Your question/description is terrible. Post pics of your unknown hoses and someone may actually be able to help. Iacv has a large hose that goes to 'intake' pipe before TB, coolant lines, and wiring.. Simple. |
12-26-2013, 11:26 PM | #5 | |
Th bottom of the throttle body goes to IAVC. The. The big tube to the cold pipe and then you have some vac lines. Be more specific take some pics and we should be able to help you |
12-27-2013, 08:43 AM | #6 |
Sorry about my descriptions
Pic 1. Where does that hose lead to ? It comes out the back of the iacv. Pic 2 where does that nossle connect to ? Pic 3 where does that connect to ? Its at the tail end of the intake ? Sent from my SGH-T999 using Tapatalk |
12-27-2013, 08:59 AM | #7 | |
pic 2 same thing, its the coolant return so it needs to have a line connected to it to allow the coolant to flow back out Pic 3 is either a brake booster or pcv fitting. Needs to connect to either the pcv on top of the valve cover, or the brake booster
