![]() Join Date: Feb 2002
*NOW IN STOCK*
![]() ISIS Performance 5 Lug Hub Conversion - Nissan 240sx 89-94 S13 These 5-Lug hubs are a direct replacement for your 89-94 Nissan 240sx. This is a full set - front and rear. Unlike other 5-lug conversions, this does not need any modifications to the spindles or balljoints. Simply remove your stock hubs and replace them with these. Specs are as follows: 5x114.3 Front Hub: * bearing & lightweight designed * Standard Wheel Studs Mounted * Compatible with all kinds slotted rotors & spacers Rear Hub: * Hub Bearing Inserted * CNC Machined for precision and accuracy * Standard Hub Studs Mounted * Easy Installation - Plug & Play Click here to order ===> http://www.enjukuracing.com/products...89-94-s13.html
