![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
GKTech - 4/5x114.3 Hub Centric Slip On Spacers
4/5x114.3 10mm Hub Centric Slip On Spacers
The GKTECH 10mm slip on spacers allow for adjustment of the fitment of your wheels. The wheel spacers are hub centric to suit Nissans 66.1mm hub and are manufactured to the highest quality in T6061 Aluminium and then hard anodized to further increase the strength Features: - CNC machined aluminium T6-6061 construction - Hub centric to suit 66.1mm Nissan hubs - 114.3mm PCD with both 4 bolt and 5 bolt holes - Sold as a PAIR Price: 49 AUD (approx. 42 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/4-5x...n-spacers.html FAQ Do I need longer studs to run these wheel spacers? Yes, your standard studs are only 26mm's in length so spacing them out an extra 10mm's without the use of longer wheel studs is probably not possible, and if so would be very dangerous. Do you sell spacers with other bolt patterns? No, if it's not listed on our website then we don't sell it. We don't do any custom work. Sorry What's the difference between these slip on spacers and others available? These wheel spacers are hub centric which means that they ensure that your wheel sits perfectly central to the hub of your vehicle. What hub size are these spacers made for? These spacers are made to suit Nissans which are 66.1mm and as such the spacers have an ID of 66.1mm and an OD of 66.1mm 4/5x114.3 15mm Hub Centric Slip On Spacers The GKTECH 15mm slip on spacers allow for adjustment of the fitment of your wheels. The wheel spacers are hub centric to suit Nissans 66.1mm hub and are manufactured to the highest quality in T6061 Aluminium and then hard anodized to further increase the strength Features: - CNC machined aluminium T6-6061 construction - Hub centric to suit 66.1mm Nissan hubs - 114.3mm PCD with both 4 bolt and 5 bolt holes - Sold as a PAIR Price: 59 AUD (approx. 51 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/4-5x...n-spacers.html FAQ Do I need longer studs to run these wheel spacers? Yes, your standard studs are only 26mm's in length so spacing them out an extra 15mm's without the use of longer wheel studs is probably not possible, and if so would be very dangerous. Do you sell spacers with other bolt patterns? No, if it's not listed on our website then we don't sell it. We don't do any custom work. Sorry What's the difference between these slip on spacers and others available? These wheel spacers are hub centric which means that they ensure that your wheel sits perfectly central to the hub of your vehicle. What hub size are these spacers made for? These spacers are made to suit Nissans which are 66.1mm and as such the spacers have an ID of 66.1mm and an OD of 66.1mm For any inquiries please e-mail us at [email protected]. Last edited by GKTECH; 08-14-2014 at 11:52 PM.. |
