Old 10-13-2005, 11:16 AM   #1
.::SR20_240::.
.::SR20_240::. is on the path to ruin.::SR20_240::. is on the path to ruin
Send a message via AIM to .::SR20_240::.
dumb 5lug question..
i have searched and i find HOW TO posts but i allreddy know how to do it, my question is can i swap a s14 5 lug to my car and put my s13 4 lug on a s14 with out having to buy any extra parts? a friend of mine wrecked his s14 and is going to sell the car to the junkyard but i want the 5lug and wheels BUT the junk yard will not take the car unless it is rolling on some wheels so going back to my question can it be done??? flaming welcome as long as its helpfull. NO
.::SR20_240::. is offline   Reply With Quote
Old 10-13-2005, 11:36 AM   #2
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
only problem i forsee you will run into is bolting the front struts to the spindles, different bolt sizes.
-Dustin
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 10-13-2005, 11:40 AM   #3
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
well, if you just want them on, yeah they should go right on, it might not bolt on 'perfectly' because of the different ball joints, and the strut bolts are going to be larger on s13 and smaller on s14 if you swap them, so you'll need sleeves, but it's going to the junkyard so that doesn't matter, jus get sleeves for your car or enlarge the holes, i think after i did my 5 lug i needed an alignment after that, well i know i needed one right after i did it, think it changed it up, oh well, hope that helps, might have left something out, someone correct me if i'm wrong
Indolent is offline   Reply With Quote
Old 10-13-2005, 12:15 PM   #4
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
you should be able to rig it so it will roll just swap and bolt on your old hubs rears will fit no prob fronts should slide on then just put the nut back on it and go I wouldnt drive it but you should be able to push it around fine
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 10-13-2005, 12:26 PM   #5
.::SR20_240::.
thanks guys it helped alot. i was going to just let the 5 lug go to the junk yard but now ill swap them on my next day off. do any of you know where i can get the sleves for my car? or am i better off drilling them out?
Old 10-13-2005, 02:11 PM   #6
Indolent
Indolent's Avatar
honestly, i'd rather get sleeves, my holes probably aren't precision accurate or whatever bs you know, but then if you're going to get coilovers you should get sleeves so you don't mess them up you know? try ebay, here's a link of an auction that ended
http://cgi.ebay.com/ebaymotors/240sx...QQcmdZViewItem
i was planning to get those sleeves so i don't have to drill holes on some nice coilovers i plan to get in the future lol
don't forget to get some s14 ball joints for your car, or use the ones out from the s14..
Old 10-13-2005, 03:04 PM   #7
the head
the head's Avatar
dont reuse old ball joints the new ones are only like 20 bucks its not worth it
Old 10-13-2005, 03:11 PM   #8
RightWheelDrive
RightWheelDrive is on a distinguished road
http://www.pdm-racing.com/products/5boltconversion.html
the sleeves are on the bottom. New ball joints are somewhere in that site as well.
RightWheelDrive is offline   Reply With Quote
Old 10-13-2005, 03:27 PM   #9
theicecreamdan
just swap over the lower control arms, extra 10mm wider is good for you, and s13 LCAs are bad for whoever pulls them off the junkyard s14.
theicecreamdan is offline   Reply With Quote
