Im new to this nissan scene. Came in clueless but i was tired of hondas.. I have a s13 coupe and its automatic. I want to make it stick what do i need besides the obvious.. Im not big on bigger engines and what not as i had my license suspended 2x and i dont want to lose it again. i simply want a reg engine but nice looking car. I will weld my diff though to have a little fun.
I know i need : Tranny, pedal, tranny mounts, and i need to rewire some shit in the ecu i was advised.. Can someone tell me everything i need i want to have this car done before it gets warm out im in pa. Thanx... P.s fuck hondas. ive had my s13 since december and i love it. more torquey and fun to drive thn a civic. . once again thanx for your time and help |
#/f/tech-talk/387225...-progress.html
You would need flywheel bolts because the a/t ones are to short, you would need to take out the automatic pilot bushing and replace it with a manual 1, you would need a master and slave cylinder. you would need to cut the holes for the slave cylinder. you would need to splice the park/neutral. you would need to hook up your reverse wires, you would need a manual speed sensor, you would need a clutch kit, flywheel. you would need a driveshaft, you would need a shifter. its pretty easy. its just having all of the parts and taking off that damn auto transmission, torque converter and flywheel thats a b**ch. just follow the link i gave you. good luck. |
| engine, sr20det, swap |
