![]() Join Date: Jul 2003
My S13 blacktop has a serious problem but Im not sure what exactly. Here are my symptoms:
#2 Cylinder shows 90psi, 1,3,4 show 145+ *Oil catch can fills up/overflows in a number of minutes of hard driving *Found oil on all sparkpulgs (aka in combustion chamber) *Exhaust stinks badly (much more than usual) but doesnt really smokeCan you tell from that if its something in the head or a ring? Also I think my turbo is on its way out, that could be adding to it. Please help ![]() |
![]() Join Date: Oct 2003
your rings are shot, pour a little oil into the cylinder and then try the compression test again it should go up a bit (mine went from 70->90). Right now your boost is blowing past the rings and taking all your oil with it...time to pull the motor apart =]
