Stock Fog w/ Intercooler Piping?
Doing an Rb25 swap in my Kouki wanted to know if im still able to retain my fogs while having intercooler and piping installed? Bought some 3000k Hids never used em...
Man w/ CTSV & a Car Seat
Not with most FMIC kits. You can do a custom FMIC and keep your fogs if you want. You can flip your core upside down so the inlets and outlets are higher up, then build the pipes to fit that setup.
#3 | |
Thanks man |
![]() Join Date: Sep 2006
^same. probably gonna have to run custom pipes to clear
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
Yep, agreed. If you want factory fogs, custom is in order.
My SR20VET |
