5 speed swap ECU problem
I have the car running im pretty sure everything works on the auto ecu, i plug in the manual ecu i have no rpm guage car runs for 5 seconds then mutters to its death. Any ideas?
the auto ecu is better
since the limiters r basically non existent with the auto ecu manual ecu stops at 115mph auto ecu stops at 135mph
シチサn w/ka20det:in progressシチサnw/sr20det:stolen |
![]() Join Date: Dec 2004
Trader Rating: (58)
Auto ECU will only throw codes related to the lack of Automatic Transmission if you do pull the CEL codes, assuming there were no codes to start. For it to only run for 5 seconds is not going to be ECU related (unless something is burnt in the ECU, but that would be the last troubleshooting check)
