Greddy TurboTimer in 93 key removal issue
Hey guys I recently put a greddy turbo timer in my car. The button on the ignition won't let the key turn and pull out, until the timer hits 0.00 and turns off. Do I have to disable the button? If so, can someone post a link. I'm having trouble finding anything.
![]() Join Date: Jan 2012
Is there a switch on the back of the unit? My Greddy unit has a switch on the back, I've switched it accidentally a couple times when removing/installing. With it switch it wouldn't let the timer work.
If that's not it, you might have to set up the timer part, I forget the sequence as my cars been off the road for about a yr now. Greddy website I think has the users guide to download. |
![]() Join Date: Jun 2007
This can be fixed in 3 simple steps:
1. Remove turbo timer 2. Throw it in garbage 3. Repair points on harness where TT was spliced in.
Lol, I hear you man but it also serves as my volt meter, I found it in the trunk after I bought the car.. I have the stock t25 garret on a blacktop sr20 it wouldn't hurt to let it idle for an extra 30 seconds
