![]() Join Date: Apr 2007
![]() ![]() Feedback Score: 11 reviews
Rear subframe question, simple, Ive searched!
Hi, yes, Ive searched and looking to do a NON hicas subframe swap on my R32! I preffer to avoid using S14 offset bushing subframe! So im wondering if:
#1 Any (most likely Newer) S13 came with 2 bolt diff cover bolts setup? and #2 Z32 NON hicas subframe interchangabel with S13 or S14? Without offset bushings! Basically im looking for NON hicas subfame for my R32, im avoiding using S14 or 4 bolts diff cover S13! Thanks |
S13 subframe is identical to a r32 sub frame without hicas and drops in with no mods. If you go the s14 route you will have problems with the Ruca's hitting your coilovers and frame rails.
![]() Join Date: Mar 2012
Trader Rating: (68)
![]() ![]() ![]() ![]() Feedback Score: 68 reviews
1# - All s13 and r32 are 4 bolt. S14 runs a 2 bolt. Switch covers if needed. Plug and play
2# - Do offset bushings, you can technically get into the sketch area and force the studs to work with the bushings. That is up to you. Might work or might fail severely. Its better just to do it right and buy a s14 or s15 subframe and run the correct offset bushings Do it right, don't half ass. Question just answered.
Straight Outta The Slums of Shaolin |
R32 in my case GTRs are never ever 4 bolts diff covers! So previous person ^ is incorrect! Not a single clear answer from both of you, let me try to rephrase myself:
#1 I read somewhere that newer S13 subframes have different angle on the lower control arms, so my question is if Rear subframe was changed over the years from 4 bolt diff cover to two bolt one!? #2 I know you can make everything work in anything but, without modifications and using offset bushings, ZZ32 NON TTURBO, non hicas subframe is directly interchangable with s13 or S14! Please before answering read the question carefully! |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Was there ever an update to s13? I didn't think there was. S13 is s13, 4 bolt diff and the same geometry throughout the years.
S14 had the better geometry for the LCA, and they use 2 bolt cover diffs. The diffs covers are interchangeable so not sure what the problem is.... Last edited by e1_griego; 11-25-2014 at 04:00 PM.. |
The s14 got the RLCA mount update, two bolt diff, and 10mm wider. Late s14 got additional reinforcements, s15 continued this setup. Z32 subframe is a whole lot wider and I don't think it will fit an s/r32 chassis at all. If the OP's main goal is the geometry update then he has to do s14/15 with offset bushings and just swap the diff cover for a 2 bolt, not hard at all and I don't get the fuss.
S12 || KN13 || S13 || B16 |
The fuss is about people not reading the questions here, IM ASKING 3rd time please read the question:
In the very first post it says: " looking to do a NON hicas subframe swap on my R32 " GTR if its matter, NISMOPLSR, I hope this explains what my goal is! #1 I already bought R32 GTR (same as S13) NISMO rear subframe and diff bushings, so i want to use them and I hate the idea of using SOLID bushings there! SO my choices S13 (4bolt) or R32 (hicas) #2 Cant believe that people still recommend me to switch to a two bolt cover after 2 times explaining myself, I DO HAVE A STOCK R32 GTR 2 BOLT DIFF COVER, and I WANT TO KEEP it since it is FINNED and it looks like it allows more volume of gear oil in diff (it has that bulge) Forget about previous questions guys, I will try this thread with another question: Which cars cam with 4 bolt bulge rear diff cover??? |
Trader Rating: (24)
Pretty sure only s13 had 4 bolt covers. There are 2 or 3 different styles of s13 covers, though, so maybe that's where you're getting confused. You can buy a brand new high capacity one from nissan (e.g. http://www.frsport.com/Nissan-38351-...e_p_26018.html).
![]() Join Date: Feb 2009
To answer your original questions.
#1. All S13 subframes support 4bolt diff covers. Not sure what to tell you besides putting a 4 bolt cover on your diff. #2 No z32 subframes are not interchangeable with S13's Now for the newest question. I don't know what you mean. My stock s13 240 rear has a bulge in the cover and looks like the picture. All s13 covers that I have took notice to had a bulge. |
#13 | |
I personally witnessed that there is 2 different covers! Im pretty sure there is still one completely plain cover! Im pretty sure, im going to go with S13 subframe with bulge and finned rear 4 bolt cover! Now, wondering which style is better, 2 bolts with bushings or 4 bolts solid bolt on!? |
![]() Join Date: Apr 2013
The 2 styles of covers bolt on the same one just holds more fluid..
And solid will technically get the power to the ground better but with more vibrations. S14 diff with bushings won't vibrate ad much but you could lose a tad bit of torque (not enough u could even feel) |
#15 | |
![]() Join Date: Jun 2010
If you are going to use the S13 subframe, you will not be able to use the 2 bolt rear cover. As for which is better, that depends on what you consider "better" to be. You posted that you have Nismo bushings because you don't like solid. The bushings used by the 2 bolt cover (and forward mount) will transmit less vibration but at the expense of rigidity and putting down the power. The 4 bolt cover (and diffs that do not use bushings at the forward mount) will have maximum rigidity but at the expense of increased NVH. |
What the hell is all this rambling? Why not just buy the hicas eliminator kit and be fucking done with it? The only thing you need to swap would be your damn bushings.
My SR20VET |
#17 |
Dont remember asking for any ATTITUDE - jr_ss, Dont make me explain why I want to totally eliminate hicas, it will take me 3 - 4 times in the end!!!
Im afraid to ask this, but does Q45 rear subframe is any similar to S13, S14 or Z32?? Here is the GTR diff that im going to use, the cover holds 2 ABS/Atessa sensors, any 4 bolt covers have support for them? |
#18 | |
What is your end goal? Why do you not want to eliminate HICAS via the kit?
My SR20VET |
#19 | |
![]() Join Date: Apr 2006
Nothing worse than hearing people complain when they dont get the information they are seeking. Just remember dick head, prior to forums people had to do their own homework. You should consider yourself lucky that this place even exists for you to come and cry on... This guy makes me want to choke him through the monitor. |
#20 |
Now see, this person should be ignored, i dont know what his problem is... Most likely he is jealous of me owing a GTR! 5000+ posts, wonder how many of them is on the subject, none in my thread!
jr_ss, i don't want to use hicas bar because i still have to use rear knuckle toe balljoints, and i need to replace them! But even if they are good, they still not providing the SOLID feel of the rear end! BUT i guess, i have to, since there is no other options! What exactly is wrong with my first post that hasn't been edited since day one!? And only because of this thread i figure out that S13 subframe would NOT WORK, diff cover dont have abs sensors support! So, thanks everybody! |
