![]() Join Date: Mar 2005
Which clutch to use...
Hey guys, I'm gonna be swapping an sr20det into my '93 240 soon and was wondering what you guys thought I should do for a clutch. I figured I might as well do the clutch too while everything is out of the car and easier to work with/get at. The car will be street driven, most likely on stock sr20det for this summer, but by next Spring at the latest I want to upgrade the turbo and put down some real power
. So I was wondering what you guys use and how you like it, how it held up to your power and how it drives on the street. As of right now I was leaning towards ACT or Exedy. Also, whats a good site to get them for a good price?Please give me your unbiased opinions. Thanks. |
![]() Join Date: Mar 2004
just save money and use your stock clutch that comes with the motor, sometimes its already aftermarket. i been using the stock sr clutch for a while w/o slippeage, use that time to find a good price on a clutch... exedy stage 2 is good, or a spec stage 3.. most people hate spec though.. ACT is ok too but i would never use ACT again.
![]() Join Date: Jun 2004
use exedy stage one(stage 2 is more aggressive). better than stock, will hold up to 280, last a while.
spec is good but a lil more $$. hint: ebay is your friend
hydropgrahics! ![]() ls1...... |
i was looking to push more than 280 come spring and dont wanna kill my somewhat new clutch and have to buy a new one.
i'm also debating leaving the stock clutch, but i figured it'd be easier while the motor and tranny is out of the car already |
#6 | |
93 fastback SE, 200k+ miles redtop sr, act clutch, d2's, kaaz 1.5 way, 13 psi, bnports/vertex knockoff aero |
If the clutch still has material left, keep it. Otherwise, get a Spec Stage 2. The one I have feels just like a stock clutch, but holds better.
Check this out: a 217 rwhp WRX beats one with 331 rwhp. 13.6 vs 13.8 sec in 1/4 mile. Why? because of their choice of clutches! http://www.sportcompactcarweb.com/fe...0308scc_sti01/ Although the SPI WRX has more HP because of a larger turbo, it's slow to build up boost. The quick fix is to slip the clutch, but the SPI had a clutch that would not slip, so at boost all the power is wasted by burning out the tires. |
#12 | |
![]() Join Date: Apr 2003
I'm looking for a new clutch too..I'm around 300hp now and the stock one isn't the best at the moment.. What u suggest? I use it daily and for drifting.. so I don't want a hard pedal or a jumping clutch.. stage 2 normally use puck clutch and I'm afraid about unstreetable..
![]() Join Date: May 2005
I am looking at pushing around 250-265 at the crank and I have the Exedy Stage 1 sitting in my room. I have been told that this clutch is good enough to handle what I am looking at doing, since my car is being built for response and not total power. I would say for bigger power peeps(300+) Spec made a nice combo with carbon disc, pressure plate, and flywheel for around 650-700. Might want to look at that.
![]() Join Date: Feb 2003
Horsepower has nothing to do with clutch holding ability.
It's torque. Act's are underrated and run on cars making well over ACT's max torque rating. I can't believe nobody's chimed in about RPS clutches yet... hint hint Or the white bunny special. Bigger surface area, higher torque rating, smooth ass pedal feel.
My car has been sold |
#16 | |
#17 |
i got my clutch from here:
http://www.horsepowerfreaks.com/pric...ls/Clutch_Kits i got the clutch masters stage 1 kit and its not too aggresive and its a cheap price. better than stock |
#19 | |
which of those 3 brands is designed specifically for drifting? which of those 3 brands has a zero failure rate (defective product) to date? Max |
#21 |
back in 2000~2001 some guy in PA had a Z32TT pushing 550hp or so (the numbers are fuzzy in my head) at the wheels on that profile clutch
superior clutch has the dyno sheet somewhere down at his shop a VG30DETT uses a 250mm clutch (i think) a little bigger than a KA or SR on a AE86 200mm flywheel some local guys just cranked out 260 hp 230 tq at the wheels with no problem my guess is that the 200mm setup can do aprox 350 to the wheels so a 225mm in a KA should do 450+ and a 240mm is a SR20 should do 550+ but we will never know unless some one breaks one of these guys (which has not happened to date) and backs up thier hp/tq numbers on a dyno Max |
#22 |
i have the spec stage three and im VERY happy with it. i also have a couple friends with them and we've all had good luck with our clutches. its a 6 puck sprung clutch, but it still daily drives soemwhat. i love it though. definetely recommend it
www.ohiodrifting.com |
#23 | |
Thanks for your support. Also check out our line-up of ATS clutches. Rumor has it they actually supply the carbon disks for the Exedy clutchesLast edited by ma71supraturbo; 06-16-2005 at 06:04 PM.. |
#24 | |
![]() Join Date: Mar 2002
I volunteer to test one Is Gabe going to use one on the s13?
![]() sentinelguild.com/nzo/PFCDB/ |
#28 |
well what do you suggest then? i need something that will hold a decent amount of power (around 350-400 to be safe for when i upgrade my turbo over the winter)
#29 |
![]() Join Date: May 2003
SPEC sucks ass. im using the stage 2 on my ca18det and its horrible, super soft pedal feel, worse than a slipping worn stock OEm clutch. does not resist fade too well. a few clutch kicks and drift nights and i already felt a huge difference. my main point, go anywhere besides to SPEC, unles you want to be swapping out clutches under a year
