| Group Buys Dedicated Forum for Group Buys. |
![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
GODSPEED Suspension Page!!
Full line of Godspeed Suspension for S13 & S14 IN STOCK!!! Ready to Ship and Pick Up!!! GODSPEED Type-RS, Coil-Over Dampers is the perfect enhancement to your track or street car. Featuring 16 Levels of damper force adjustment, full-height adjustment. The damper can easily adjusted by turning the knob at the top of the damper. Turning the knob can simply change your daily driving or track day needs. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can easily raise your car to oem height or lower your car for track performance. The quality and durability of the GODSPEED Racing Damper kits are made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. we stand by our product with 1 YEAR warranty. (from date purchase. Must be installed by professional tuning shop) 89-94 240SX (WILL FIT 180SX ALSO ) S13 TYPE-RS coilover suspension damper (16WAY Damper Adjustable) NISSAN 240SX S14 95-98 TYPE-RS SUSPENSION COILOVER (16WAY Damper Adjustable) Features: - Spring Rates: 8kg Front and 6kg Rear - Pillow Ball Upper Mounts. - Rubber Dust Covers. - Adjustable Ride Height .5" - 3.5" - 16 Levels of Adjustable Damper - Single-Cylinder Design -1 Year limited Warranty GODSPEED Type-SS w/ Pillowball Upper Mount and Dual Height Adjustments is an high end performance coilover setup designed for everything from daily driving to track competitions. This coilover exhibits superior handling characteristics with the added performance of solid (non rubber) type pillowball upper mounts for an ultra responsive suspension package. Coilovers will come ready to install w/o having to reuse stock OEM rubber mounts. This GODSPEED suspension coilover kit offers superior handling, adjustability, and customizability for all your high performance driving needs. . The quality and durability of the GODSPEED Racing Damper kits are made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. we stand by our product with 1 YEAR warranty. (from date purchase. Must be installed by professional tuning shop) NISSAN 240SX S13 89-94 TYPE-SS SUSPENSION COILOVER 89-94 240SX (WILL FIT 180SX ALSO ) S13 TYPE-SS coilover suspension damper NISSAN 240SX S14 95-98 TYPE-SS SUSPENSION COILOVER Features: - Spring Rates: 8kg Front and 6kg Rear - Pillow Ball Upper Mounts. - Rubber Dust Covers. - Adjustable Ride Height .5" - 3.5" - Single-Cylinder Design -1 Year limited Warranty NISSAN S13 240SX 180SX 89-94 FRONT SWAY BAR Front 30.05mm (Solid) Solid Bushing (use Stock Backet) LIFE TIME WARRANTY!! NISSAN 240SX S13 89-94 REAR SWAY BAR Rear 28.3mm (Solid) Solid Bushing (use Stock Backet) LIFE TIME WARRANTY!! NISSAN 240SX S13 89-94 Adjustable Rear Toe Arm Up to 3 degree Also Fit 300ZX Non-turbo and R32 Skyline NISSAN 240SX S13 89-94 REAR CAMBER ADJUSTER NISSAN 240SX S13 S14 89-98 PILLOW TENSION RODS NISSAN 240SX S13 S14 FRONT & REAR LOWER CONTROL ARM 89-94 Nissan 240sx (S13) 89-94 Nissan 180sx (j-spec version) 95-98 Nissan 240sx (s14) NISSAN 89-94 S13 95-98 S14 90-96 300ZX TRACTION RODS NISSAN 240SX S14 95-98 FRONT SWAY BAR Front 30.32mm Solid Bushing (use Stock Backet) LIFE TIME WARRANTY!! NISSAN 240SX S14 95-98 REAR SWAY BAR Rear 28.16MM Solid Bushing (use Stock Backet) LIFE TIME WARRANTY!! NISSAN 240SX S14 95-98 ADJUSTABLE TOE ARM Also Fit R33 and R34 Skyline NISSAN 240SX S14 95-98 REAR CAMBER ADJUSTER NISSAN 240SX 89-94 GODSPEED CROSS BAR (hb only) NISSAN 240SX 89-94 6 POINT ROLL CAGE Fit Coupe and Fastback !!(also Fit moon roof but headline and A & B pillar plastic panel need to remove!!) PM or CALL US FOR THE BEST PRICING!!!(Tell Us You from Zilvia.net For Better Discount) We are S13/S14 Specialist, if you cant find what you need check out our website GodSpeed Project - Intercooler, Turbo Kits, Turbo Manifold, Body Kit or give us a call if you have any question!! We also have other GB on the forum, so please check them out!!! Ken @ Fatboy Garage Motorsport 11135 Rush St Unit B South El Monte CA 91733 626-442-3988 Last edited by Fatboy Garage; 08-21-2009 at 12:50 PM.. Reason: Add more item |
![]() ![]() DESCRIPTION : NISSAN 89-94 240SX (HB ONLY) godspeed 6 point anti-roll-cage (PROFESSIONAL INSTALLATION ONLY!!) -40mm seamless carbon steel , prebent tubing -bolt on design with bolts & mounting plate -comes in silver color Our roll bars and cages meet or exceed the safety requirements for most off road track. This will reduces the body roll by 40% or more. Perfect for hard corner tracks /drifting. Our bars and cages have been designed to easily install and provide maximum protection. The fit in your vehicle allows quick and easy entry and most importantly, quick exiting, while conforming closely to your interior for a clean, unobtrusive look and feel. All of our bars and cages are certified MIG welded and precision jig notched, providing you with the maximum strength and best fit available. Every roll bar or cage has been designed to fit ??specific car models so only minor ??modifications are necessary for the instal??lation. Most applications are a true bolt-in and require NO WELDING. |
![]() Join Date: May 2003
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
i dont want the cage im just asking to make it easier for potential buyers pretty sure this cage is more form over function...just dont want people getting screwed out of their money when they find out it doesnt meet their tracks standards. edit...thanks for the info
#16 | |
but thanks for you input tho. Thanks Ken,S |
Trader Rating: (33)
im serious about the cage
tracks have certain safety guidelines thats why i was asking as for the hb bar...im still waiting on the price??
#19 |
do you only sell the cross bar with all those crazy parts?
What if you just want the "X"
#25 |
New Update!!!
the Cage will Fit Fastback,Coupe and Moon Roof!!! (Moon roof model need to remove Headline,A B pillar Panel(plastic piece) ) Thanks Ken,S |
#28 |
Pm what the best price i could get if i bought, the rear and front sway bar kit,rear toe arms, pillow tension rods, and traction rods at once
to 28214, thanks! Godspeed for the MF win!!! Car is 92 s13 |
