![]() Join Date: Sep 2012
What turbo flange is this
Trying to figure out what outlet flange this is. It's not a t25/28 and it doesn't look like a t3/t4 one either so I'm stumped ImageUploadedByTapatalk1431880614.466166.jpgImageUploadedByTapatalk1431880642.963460.jpg
![]() Join Date: Jul 2006
I've always knew them as 5 bolt exhaust flange.
Check out my build thread! #/f/builds-builds-on...rhd-build.html |
ImageUploadedByTapatalk1431881278.214071.jpgthats a t25/28 old gasket and it doesn't match
![]() Join Date: Sep 2005
It's 5bolt ford style, you should know this, because you'll need a new dump pipe flange or have a vband flange welded onto the Ford 5bolt flange, blah blah etc.
Sent from my Highly Tuned Note 4.5!!!
Yeah knew I'd need a new dump pipe. I was curious cause my supervisor said I could use it but when I saw the rear I didn't know what kind of flange it would be. He said he got it for a upgrade for his car overseas but never used it but idk if I'll pursue it now
![]() Join Date: Oct 2014
Looks like a cheap ebay turbo. I'm not sure about the flange and didn't bother looking up a ford flange that someone above said it is. Either way, it looks as if the internal wastegate is still on and that flange will need to modified to have a dump pipe or something of the sort for the wastegate gases.
#8 | |
Ok potatoes / french fries
