![]() Join Date: Nov 2010
Good questions. If you have any of the coil pack cover screws, Test the size and use that to
Gauge what you need if you can't get an answer.... Then I would go to ace hardware or similar with the cts housing and said screw to compare and a some that maybe extend 3/8-1/2 inch past the housing. Doesn't look very deep in reference to your picture.
