Guest
Posts: n/a
Yea so I'm looking to replace my plugs and wires...my friend with a new miata said to get some plugs called irinium or something that sounds like that.
What can I get that will give me the biggest boost in HP? Thanks, Chance |
Guest
Posts: n/a
ok I just talked to my friend and he said get magnecore wires and Benson Iridium plugs? Does that sound good guys?
I found the wires for $89.95 Thanks, Chance |
Guest
Posts: n/a
wait..I think that's Denso...right?
![]() Join Date: Jul 2001
Yeah your right your thinking of Denso, here's the link to a prior post about this.... #/forum/topic.cgi?forum=2&topic=381
Krunko that is exactly what I am getting.
The Denso plugs with Magnecore wires, Ive done a bit of researching and it seems to me that its the best setup for the money. I should be getting mine in a few weeks and Ill post a review here for others to read. If you get yours first let me know how they do please, cheers |
hi fello nissan buddy ill tell you a trick you can get any plugs ... even the cheaps ones all you have to do is ground cut them... and you will be amazed.. i would reccomend magacor wires there good...but remeber just gap the plugs after ok have fun
I have the nology hot wires, they're really good on the highway, it feels like another gear when u gun it. but nevertheless, i am running the HKS drag racing plugs, which are heat-11. i cant't wait for the cash to upgrade to the HKS twin power ignition.
Man,
If you want a wire and plug combo that will blow your mind and pump up your top end get Nology Hotwires and nology plugs. The most wires look great and give a little extra charge, but Hotwires fire about 100 times the charge of your average wire. Check out their site www.nology.com. The ran me $280 (Canadian), do the math, and $40 for the plugs. They look great and run awesome. |
OMNOMNOMNOM
![]() Join Date: Dec 2000
Even with a turbo system you wont really notice much of a gain from Plugs / Ignitoin Systems / Wires.
If I were you I would stock with a NGK Platnium Plug. I have the Iridium's by NGK and they work fine but I dont see spending the extra $ for nothing. Wires is simple... Magnecor are one of the best IMHO, but all do about the same. Nology is trying to sell a name more than a product, but still are good units. You will notice after installing these that your car will run smoother and it will get to redline a little quicker, with maybe a few extra ponies. |
![]() Join Date: Jun 2001
imho, even a few ponies are worth it <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> Anything I can get out of my engine i'm going to.
#19 |
Guest
Posts: n/a
Best wires and plugs will give you 3-5 horses MAX. You guys listed all the best ones up there, so i have nothing else to say <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>.
